[GeoNode-users] Updatelayers failed
Jose Cáceres jose.atyus at gmail.com
Fri Feb 7 11:42:09 PST 2020
Hi everyone,
Hope everything is well.
I'm running geonode 2.10 using docker instance as per this instructions:
http://docs.geonode.org/en/2.10.x/install/core/#docker
I'm running it on a local IP, not localhost directly, but I thought
everything went well with the installation since I could load the page,
load geoserver, uploading a layer using the upload function form the site,
I could dump me own database into geonode_data and I could see my layers in
geoserver, all as shown in the screenshots attached.
However, when I try to import my data to geonode from geoserver, using the
updatelayers command I get the following error message.
So I enter the container running:
docker exec -it geoserver4geonode /bin/bash
The I ran:
python manage.py makemigrations
python manage.py migrate
python manage.py migrate --run-syncdb
Everything went without any issues. Then I tried:
DJANGO_SETTINGS_MODULE=geonode.settings python manage.py updatelayers -w
geonode --skip-geonode-registered
And got the following error:
  File "manage.py", line 29, in <module>
    execute_from_command_line(sys.argv)
  File
"/usr/local/lib/python3.7/site-packages/django/core/management/__init__.py",
line 381, in execute_from_command_line
    utility.execute()
  File
line 375, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File
"/usr/local/lib/python3.7/site-packages/django/core/management/base.py",
line 323, in run_from_argv
    self.execute(*args, **cmd_options)
  File
line 364, in execute
    output = self.handle(*args, **options)
  File
"/usr/src/app/geonode/geoserver/management/commands/updatelayers.py", line
98, in handle
    owner = get_valid_user(user)
  File "/usr/src/app/geonode/people/utils.py", line 46, in get_valid_user
    theuser = get_default_user()
  File "/usr/src/app/geonode/people/utils.py", line 37, in get_default_user
    raise GeoNodeException('You must have an admin account configured '
geonode.GeoNodeException: You must have an admin account configured before
importing data. Try: django-admin.py createsuperuser
Then I tried passing the flag user to the previous command, like this:
DJANGO_SETTINGS_MODULE=geonode.settings python manage.py updatelayers -u
admin -w geonode --skip-geonode-registered
  File
    utility.execute()
  File
  File
  File
  File
98, in handle
  File "/usr/src/app/geonode/people/utils.py", line 48, in get_valid_user
    theuser = get_user_model().objects.get(username=user)
  File
"/usr/local/lib/python3.7/site-packages/django/db/models/manager.py", line
82, in manager_method
    return getattr(self.get_queryset(), name)(*args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/django/db/models/query.py",
line 408, in get
    self.model._meta.object_name
geonode.people.models.DoesNotExist: Profile matching query does not exist.
No luck either, I can log to the site using the default credentials, but I
haven't created any other users, is that necesary in order to use the
updatelayers?
Thanks in advance for all your help!
José
José David Cáceres
Ingeniero Ambiental
Máster en Tecnologías de la Información Geográfica
e-mail: jose.atyus at gmail.com
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200207/d485f91f/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200207/d485f91f/attachment-0003.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200207/d485f91f/attachment-0004.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200207/d485f91f/attachment-0005.jpg>
More information about the geonode-users mailing list
