[GeoNode-users] Features not shown in attribute table
Alexandria Shreffler aleshreffler at gmail.com
Tue Apr 20 07:39:47 PDT 2021
Hi Alessio,
See below for ows filtered browser console, with a refresh:
[image: image.png]
Also, since you mentioned GeoServer, I attempted to login to GeoServer with
GeoNode and got this message. Is this a related problem?
[image: image.png]
Am I doing something wrong when I use paver to start? When I start GeoNode
using the debugging window, GeoServer doesn't start with it, so I tried to
use paver to start GeoServer separately in the terminal. It's saying port
8080 is already in use. I'm trying to run through steps in my head to
figure out where the port is being used, but I'm out of ideas and not sure
if that is even the direction I need to be going.
[image: image.png]
This is a screen shot of port use before and after running paver
start/stop:
[image: image.png]
Thank you for your help! I copied my advisor into this email as he has also
been working with me on this issue and we are trying to figure this out
together.
Alex
On Tue, Apr 20, 2021 at 3:43 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hello Alexandria,
> I see many errors, but cannot recognize from this screenshot anyone
> related to WFS or WMS-T requests.
> Could you maybe add a filter like "ows" and try to close and open again
> the feature editor window?
> Basically what I'm looking for is some error coming from GeoServer.
> Something probably related to the layer permissions (just a guess).
> Cheers,
> Alessio.
> Il giorno lun 19 apr 2021 alle ore 17:21 Alexandria Shreffler <
> aleshreffler at gmail.com> ha scritto:
>> Alessio, here is a screen shot of the debug window:
>> [image: image.png]
>> On Mon, Apr 19, 2021 at 3:48 AM Alessio Fabiani <
>>> Hi Alexandria,
>>> can you open the browser debug window (F-12) and see if there is any
>>> failing request around?
>>> Il giorno ven 16 apr 2021 alle ore 19:35 Alexandria Shreffler <
>>>> Hello, all!
>>>> I was hoping I could get some ideas on why the attribute table on my
>>>> installation of GeoNode is not showing any features. It doesn't seem to
>>>> matter the feature type (polygon, point). Feature editing and styling
>>>> appear not to be working correctly either.
>>>> I installed GeoNode on an Ubuntu 18.04 virtual machine using Pycharm as
>>>> described here:
>>>> https://github.com/gannebamm/geonode-workshop/tree/main/00_getStarted
>>>> [image: nofeatures.PNG]
>>>> *Alexandria Shreffler*
>>>> Geospatial Analyst, Venango County Regional Planning Commission
>>>> Pursuing Master's in GIS, Pennsylvania State University
>>>> B.S. Psychology & Environmental Studies, Allegheny College
>>>> *Phone: (814) 758-4187 or (814) 670-0897*
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
>> *Reply from Alexandria Shreffler, Geospatial Analyst for the Venango
>> County Planning Commission.*
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
*Reply from Alexandria Shreffler, Geospatial Analyst for the Venango County
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210420/4e7831c3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210420/4e7831c3/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210420/4e7831c3/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210420/4e7831c3/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210420/4e7831c3/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210420/4e7831c3/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210420/4e7831c3/attachment-0011.png>
More information about the geonode-users mailing list
