[GeoNode-users] migration geonode 2.4 to 3.1 ubuntu 14.04
Enzo Cocca enzo.ccc at gmail.com
Mon Jan 25 01:34:12 PST 2021
Sounds good!
Just to be sure: when you say "make a new installation on another machine"
it means after geonode db backup  I can upgrade ubuntu to bionic version
example, I can  install geonode 3.1  and then make the migration?
E
Il giorno lun 25 gen 2021 alle ore 10:17 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Hello Enzo,
> sure it is possible, even though not that easy to achieve.
> I would suggest to:
> 1. Backup the DB
> 2. Make a new installation of GeoNode 3.1 on another machine
> 3. Restore the DB and run migrations
> 4. Fix the DB errors while occurring (this is a boring action that must be
> done manually, unfortunately)
> Good luck,
> A.
> Il giorno lun 25 gen 2021 alle ore 09:57 Enzo Cocca <enzo.ccc at gmail.com>
> ha scritto:
>> Hi people,
>> I have some questions:
>> Is it possible to migrate geonode 2.4 to 3.1 on ubuntu 14.04?
>> If not what you suggest as steps to upgrade geonode and ubuntu?
>> thanks in advance
>> Best
>> E
>> Enzo Cocca PhD
>> in "Science and Technology for Archaeology and Cultural Heritage"
>> ISMEO
>> International Association of Mediterranean and Oriental Studies
>> mail: enzo.ccc at gmail.com
>> cell: +393495087014
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
Enzo Cocca PhD
ISMEO
cell: +393495087014
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210125/3a530a99/attachment.html>
More information about the geonode-users mailing list
