[GeoNode-users] Raster series as temporal layer
Alexander Petkov greenkov at gmail.com
Tue Jan 26 00:57:23 PST 2021
Any ideas as to why the Timeline widget is not visible on a map for a Layer?
This is the result from a wmts DescribeDomains request:
<Domains version="1.1">
<SpaceDomain>
<BoundingBox CRS="EPSG:4326" minx="-156.661" miny="-45.642" maxx="178.039"
maxy="74.034"/>
</SpaceDomain>
<DimensionDomain>
<ows:Identifier>time</ows:Identifier>
<Domain>2020-09-08T00:00:00.000Z,2020-09-09T00:00:00.000Z</Domain>
<Size>2</Size>
</DimensionDomain>
</Domains>
Then I ran python manage.py updatelayers.
However, upon viewing the layer on a map, the Timeline widget does not
appear:
https://pasteboard.co/JLoXmYkQ.png
Also, is it possible to display a Timeline widget for Raster layers
(imagemosaic) with a time dimension?
Thank you in advance!!
Alex
On Thu, Jan 21, 2021 at 6:51 AM Alexander Petkov <greenkov at gmail.com> wrote:
> I think this is what I am looking for:
> https://docs.geonode.org/en/stable/usage/managing_maps/exploring_maps/timeline.html
> On Thu, Jan 21, 2021 at 6:38 AM Alexander Petkov <greenkov at gmail.com>
> wrote:
>> I mean that in the metadata is visible start date/end date for the layer.
>> On Thu, Jan 21, 2021 at 6:35 AM Simone Giannecchini <
>> simone.giannecchini at geo-solutions.it> wrote:
>>> Hi Alexander,
>>> what do you mean by " Now I am wondering if it is possible to expose
>>> the temporal extent  as well, in the metadata viewable in Geonode "?
>>> Regards,
>>> Simone Giannecchini
>>> GeoServer Professional Services from the experts!
>>> Visit http://bit.ly/gs-services for more information.
>>> Ing. Simone Giannecchini
>>> @simogeo
>>> Founder/Director
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A
>>> 55054  Massarosa (LU)
>>> Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39  333 8128928
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
>>> On Thu, Jan 21, 2021 at 10:12 AM Alexander Petkov <greenkov at gmail.com>
>>> wrote:
>>>> Hello Simone and Geonode users:
>>>> I have configured the Mosaic in Geoserver with Time dimension enabled,
>>>> and ran the updatelayers command.
>>>> The layer is recognised and listed in Geonode.
>>>> Now I am wondering if it is possible to expose the temporal extent  as
>>>> well, in the metadata viewable in Geonode.
>>>> Thank you in advance with any pointers,
>>>> Alex
>>>> On Wed, Jan 20, 2021 at 11:28 AM Simone Giannecchini <
>>>>> Hi Alexander,
>>>>> I think this is more of a GeoServer related question.
>>>>> If you can set up an ImageMosaic in GeoServer then you can use the
>>>>> updateLayers management command and have this layer become a GeoNode layer.
>>>>> Obviously the work is a little more complicated than that, I was just
>>>>> trying to give you some directions.
>>>>> There are quite a number of documents around for setting up a raster
>>>>> time series in GeoServer...
>>>>> Regards,
>>>>> Simone Giannecchini
>>>>> @simogeo
>>>>> Founder/Director
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>> On Wed, Jan 20, 2021 at 1:56 PM alexander-petkov <greenkov at gmail.com>
>>>>> wrote:
>>>>>> I have the same question--Is it possible to expose the Time dimension
>>>>>> for a
>>>>>> raster layer in Geonode?
>>>>>> The layer is updated daily, so the time dimension changes.
>>>>>> Kind regards,
>>>>>> Alex
>>>>>> Sent from:
>>>>>> http://osgeo-org.1560.x6.nabble.com/GeoNode-users-f5185389.html
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210126/258683d6/attachment.html>
More information about the geonode-users mailing list
