[GeoNode-users] MapStore/GeoNode: Pass the sources object of the map to the settings
1520 gis juliermeopensourcedeveloper at gmail.com
Fri Jun 25 07:50:33 PDT 2021
Dear Alessio,
Thank you very much for your reply.
According to
https://mapstore.readthedocs.io/en/latest/developer-guide/maps-configuration/#wmts,
we have some Map Options: projection, zoom, layers, units, center, etc.
Some of these Map Options / variables are available in the settings.py (
https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L1398,L1403).
To which file these variables are passed? The reason I am asking is because
I can try to pass the MAP 's source object straight in this file.
Thank you very much for your time in advance
Kind regards
Julierme
On Fri, Jun 25, 2021 at 10:45 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> @Stefano Bovio <stefano.bovio at geo-solutions.it> any idea?
> Il giorno ven 25 giu 2021 alle ore 13:41 1520 gis <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Hill all, I got to load a WMTS Basemap Layer in MapStore/Core following
>> https://mapstore.readthedocs.io/en/latest/developer-guide/maps-configuration/#wmts.
>> WMTS Layer requires a source object in the sources object of the map
>> configuration where to retrieve the tileMatrixSet. Everything is working
>> smoothly in MapStore/Core. Now, could anyone point me on how to pass the
>> sources object of the map in GeoNode settings.py? Any direction will be
>> very appreciated.
>> Thank you for your time in advance
>> Kind regards
>> Julierme
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210625/70c038bd/attachment-0001.html>
More information about the geonode-users mailing list
