[GeoNode-users] GeoServer Error while installing custom geonode-project
Rafael Sá rafael.sa at ua.pt
Sun Dec 11 11:47:34 PST 2022
I am installing a GeoNode project on a new machine following these instructions<https://docs.geonode.org/en/3.3.x/devel/installation/index.html?highlight=paver#install-geonode-project-directly-from-scratch>, and using Postgres with PostGIS.  After run the commands paver setup and paver sync, I start with paver start but I am getting the following error:
java.lang.ClassNotFoundException: org.geoserver.GeoserverInitStartupListener
    at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:581)
    at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
    at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
    at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:543)
    at org.eclipse.jetty.util.Loader.loadClass(Loader.java:64)
    at org.eclipse.jetty.servlet.BaseHolder.doStart(BaseHolder.java:88)
    at org.eclipse.jetty.servlet.ListenerHolder.doStart(ListenerHolder.java:73)
    at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:72)
    at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:350)
    at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1445)
    at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1409)
    at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:855)
    at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:275)
    at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:524)
    at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:169)
    at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:117)
    at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:97)
    at org.eclipse.jetty.server.Server.start(Server.java:408)
    at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:110)
    at org.eclipse.jetty.server.Server.doStart(Server.java:372)
    at org.eclipse.jetty.runner.Runner.run(Runner.java:520)
    at org.eclipse.jetty.runner.Runner.main(Runner.java:565)
2022-09-29 17:46:41.378:WARN:oejw.WebAppContext:main: Failed startup of context o.e.j.w.WebAppContext at 2641e737{GeoServer,/geoserver,file:///home/odyssey/odyssey/src/geoserver/geoserver/,UNAVAILABLE}{../geoserver}
javax.servlet.UnavailableException: Class loading error for holder ListenerHolder at 38102d01{STARTING}: org.geoserver.GeoserverInitStartupListener
    at org.eclipse.jetty.servlet.BaseHolder.doStart(BaseHolder.java:95)
I can't understand what seems to be the problem here, as I installed before on other machine and had no problems.
Any help?
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221211/f258840f/attachment-0001.htm>
More information about the geonode-users mailing list
