[GeoNode-users] Disable TLS 1.0 & 1.1
Alessio Fabiani alessio.fabiani at geosolutionsgroup.com
Fri Nov 11 02:45:38 PST 2022
If that is a docker installation you can access the NGINX configuration by
typing
docker-compose exec geonode sh
edit whatever you want ant apply the conf by typing
nginx -s reload
On Fri, Nov 11, 2022 at 4:51 AM Ramesh De Silva <desilvarami at gmail.com>
wrote:
> Dear Members,
> I have installed GeoNode 4.X using Advance Core Docker guidelines in a
> production server very recently (After 4.X was declared as the latest
> stable version). Everything works perfectly. But the security team of the
> Cloud Service Provider insists on disabling TLS 1.0 and 1.1 in the system.
> As explained in nginx documentation there was no /etc/nginx folder
> probably because this is a docker installation. How can I disable this?
> Your help is much appreciated.
> Thank you.
> Kind regards
> Ramesh
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221111/b452cf24/attachment.htm>
More information about the geonode-users mailing list
