[GeoNode-users] Can not login to GeoServer
Alessio Fabiani
alessio.fabiani at geosolutionsgroup.com
Mon Oct 10 05:43:23 PDT 2022
Nope
On Mon, Oct 10, 2022 at 2:23 PM Ramesh De Silva <desilvarami at gmail.com>
wrote:
> Dear Alessio,
> Thank you for your email. I have replaced all the "localhost" entries to
> my IP in .env. Please see the image below. Are there any other places I
> need to update?
> [image: image.png]
> Thank you.
> Kind regards
> Ramesh
> On Mon, Oct 10, 2022 at 4:38 PM Alessio Fabiani <
> alessio.fabiani at geosolutionsgroup.com> wrote:
>> The locations of GeoServer are clearly wrong on the .env file.
>> They still refer to "localhost"
>> On Mon, Oct 10, 2022 at 12:30 PM Ramesh De Silva <desilvarami at gmail.com>
>> wrote:
>>> Hi,
>>> I have installed a GeoNode (4.X) using the GeoNode Master Advanced Core
>>> Docker guide in a Ubuntu 22.04 Server VM. (
>>> https://docs.geonode.org/en/master/install/advanced/core/index.html#docker
>>> All the installation steps were successfully executed and all containers
>>> loaded healthy. I have updated the IP in .env.
>>> [image: image.png]
>>> I can access GeoNode Home Page, Django Administration Page and GeoServer
>>> Home Page from the IP Address. But when I try to login to GeoServer, for
>>> some reason it redirects to localhost and fails (
>>> http://localhost/geoserver/j_spring_security_check). Please provide any
>>> possible help.
>>> [image: image.png]
>>> [image: image.png]
>>> Thank you.
>>> Kind regards
>>> Ramesh
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts!
>> Visit http://bit.ly/gs-services-us for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions Group
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> https://www.geosolutionsgroup.com/
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
Regards,
Alessio Fabiani
@alfa7691
GeoSolutions Group
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221010/67d73df5/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221010/67d73df5/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221010/67d73df5/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221010/67d73df5/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221010/67d73df5/attachment-0007.png>
More information about the geonode-users
