[GeoNode-users] Geonode 4.1.2 on RHEL 9 (Almalinux 9)
Orestes Sanchez orestes at estotienearreglo.es
Thu Aug 31 04:07:15 PDT 2023
Thank you!
I am running on a hosting platform that does not allow docker :( so I am trying it the old way :)
Regards.
Orestes.
"The Great Tao is very level and easy; but people love the by-ways"  excerpt from Holy Tao Te Ching
> On 31 Aug 2023, at 11:33, Giovanni Allegri <giovanni.allegri at geosolutionsgroup.com> wrote:
> Dear Orestes,
> unfortunately, the documentation for CentOS/RedHat is a bit old and not well maintained. For this reason, it was removed from the master version of the documentation.
> Any chance to set it up with Docker?
> Giovanni
> On Thu, Aug 31, 2023 at 1:38 AM Orestes Sanchez <orestes at estotienearreglo.es <mailto:orestes at estotienearreglo.es>> wrote:
>> Hi all,
>> We are a local association integrated by volunteers, dedicated to the history of Poblenou, a former industrial neighborough in Barcelona, Spain. We started to evaluate Geonode and succesfully set it up for Geonode 3.3.x (see it at https://geonode.arxiuhistoricpoblenou.cat <https://geonode.arxiuhistoricpoblenou.cat/>). As part of my collaboration, I am in charge of the server infrastructure. I started to prepare the migration to 4.1.x and I created a new server to test it.
>> I have a server setup with Almalinux 9. I added specific repos for Postgres and EPEL. I was following the Advanced installation guide on the 4.1.x documentation site. I followed the documentation for CentOS 7 with some tuning.
>> I managed to install tomcat 9 and geoserver 2.23 and I started geoserver successfully. I installed gdal-java, but when I start the geoserver with gdal enabled, on stopping tomcat, it produces a segmentation dump. So I finally discarded the configuration for gdal on geoserver 2.23.
>> On the postgres repository (pgdg-common) there are different versions of postgis and gdal libraries. I installed the lastest postgis33_13 and gdal35.
>> [root at geonode lib]# dnf repository-packages pgdg-common list installed
>> Installed Packages
>> SFCGAL.x86_64                                                     1.4.1-11.rhel9                                          @pgdg-common
>> SFCGAL-libs.x86_64                                                1.4.1-11.rhel9                                          @pgdg-common
>> gdal35.x86_64                                                     3.5.3-6PGDG.rhel9                                       @pgdg-common
>> gdal35-devel.x86_64                                               3.5.3-6PGDG.rhel9                                       @pgdg-common
>> gdal35-java.x86_64                                                3.5.3-6PGDG.rhel9                                       @pgdg-common
>> gdal35-libs.x86_64                                                3.5.3-6PGDG.rhel9                                       @pgdg-common
>> geos311.x86_64                                                    3.11.2-1.rhel9                                          @pgdg-common
>> geos312.x86_64                                                    3.12.0-1PGDG.rhel9                                      @pgdg-common
>> gpsbabel.x86_64                                                   1.8.0-1.rhel9                                           @pgdg-common
>> libgeotiff16.x86_64                                               1.6.0-6.rhel9                                           @pgdg-common
>> libgeotiff16-devel.x86_64                                         1.6.0-6.rhel9                                           @pgdg-common
>> libpq5.x86_64                                                     15.4-42PGDG.rhel9                                       @pgdg-common
>> librttopo.x86_64                                                  1.1.0-2.rhel9                                           @pgdg-common
>> libspatialite50.x86_64                                            5.1.0-1PGDG.rhel9                                       @pgdg-common
>> libspatialite50-devel.x86_64                                      5.1.0-1PGDG.rhel9                                       @pgdg-common
>> ogdi41.x86_64                                                     4.1.0-3.rhel9                                           @pgdg-common
>> proj81.x86_64                                                     8.1.1-1.rhel9                                           @pgdg-common
>> proj90.x86_64                                                     9.0.1-1.rhel9                                           @pgdg-common
>> proj92.x86_64                                                     9.2.1-1PGDG.rhel9                                       @pgdg-common
>> What puzzles me most is the fact that different versions of the same library are required for the installation of packages, for example, geos311 and geos312, as well as different proj version (81, 90, 92).
>> After installing python dependencies (pip install -e .) and pygdal (3.5) successfully, I tried to run `python manage.py` to test everything was right, but the command failed with a segmentation fault. I used valgrind to detect the memory leak and the problem is that some memory is created using libproj.so.25 (proj92) and then wrongly accessed on libproj.so.22 (proj81), probably due to data type incompatibility. Here it is the trace:
>> (geonode-4.1.x-py39) [geonode at geonode geonode-src]$ valgrind python manage.py
>> ==1920513== Memcheck, a memory error detector
>> ==1920513== Copyright (C) 2002-2022, and GNU GPL'd, by Julian Seward et al.
>> ==1920513== Using Valgrind-3.19.0 and LibVEX; rerun with -h for copyright info
>> ==1920513== Command: python manage.py
>> ==1920513==
>> ==1920749== Warning: invalid file descriptor 1024 in syscall close()
>> ==1920749== Warning: invalid file descriptor 1025 in syscall close()
>> ==1920749== Warning: invalid file descriptor 1026 in syscall close()
>> ==1920749== Warning: invalid file descriptor 1027 in syscall close()
>> ==1920749==    Use --log-fd=<number> to select an alternative log fd.
>> ==1920749== Warning: invalid file descriptor 1028 in syscall close()
>> ==1920749== Warning: invalid file descriptor 1029 in syscall close()
>> ==1921026== Warning: invalid file descriptor 1024 in syscall close()
>> ==1921026== Warning: invalid file descriptor 1025 in syscall close()
>> ==1921026== Warning: invalid file descriptor 1026 in syscall close()
>> ==1921026== Warning: invalid file descriptor 1027 in syscall close()
>> ==1921026==    Use --log-fd=<number> to select an alternative log fd.
>> ==1921026== Warning: invalid file descriptor 1028 in syscall close()
>> ==1921026== Warning: invalid file descriptor 1029 in syscall close()
>> Type 'manage.py help <subcommand>' for help on a specific subcommand.
>> Available subcommands:
>> [account]
>>     account_unsetmultipleprimaryemails
>> [auth]
>>     changepassword
>>     createsuperuser
>> [avatar]
>>     rebuild_avatars
>> [base]
>>     delete_resources
>>     dump_thesaurus
>>     fixoauthuri
>>     fixsitename
>>     helpers
>>     load_thesaurus
>>     migrate_baseurl
>>     migrate_notifications
>>     set_all_datasets_alternate
>>     set_all_datasets_metadata
>>     squashmigrations
>> [br]
>>     backup
>>     create_tile_layers
>>     restore
>> [contenttypes]
>>     remove_stale_contenttypes
>> [createlayer]
>>     createvectorlayer
>> [django]
>>     check
>>     compilemessages
>>     createcachetable
>>     dbshell
>>     diffsettings
>>     dumpdata
>>     flush
>>     makemessages
>>     makemigrations
>>     migrate
>>     sendtestemail
>>     shell
>>     showmigrations
>>     sqlflush
>>     sqlmigrate
>>     sqlsequencereset
>>     startapp
>>     startproject
>>     test
>>     testserver
>> [documents]
>>     delete_orphaned_files
>>     sync_geonode_documents
>> [drf_spectacular]
>>     spectacular
>> [geoserver]
>>     find_geoserver_broken_layers
>>     importlayers
>>     set_all_datasets_public
>>     set_default_gridsets
>>     sync_geonode_datasets
>>     sync_geonode_maps
>>     sync_security_rules
>>     updatelayers
>> [gis]
>>     inspectdb
>>     ogrinspect
>> [guardian]
>>     clean_orphan_obj_perms
>> [invitations]
>>     clear_expired_invitations
>> [layers]
>>     delete_orphaned_layers
>>     layer_notice_types
>>     set_layers_permissions
>> [management_commands_http]
>>     ping_mngmt_commands_http
>> [maps]
>>     changemaplayertitle
>>     remove_broken_layers
>>     updatemaplayerip
>> [messaging]
>>     purgemessaging
>>     runmessaging
>> [metadataxsl]
>>     addmissinglinks
>> [modeltranslation]
>>     loaddata
>>     sync_translation_fields
>>     update_translation_fields
>> [monitoring]
>>     aggregate_metrics
>>     collect_metrics
>>     render_metrics
>>     updategeoip
>> [notifications]
>>     emit_notices
>> [oauth2_provider]
>>     cleartokens
>>     createapplication
>> [people]
>>     setupsociallogins
>> [rest_framework]
>>     generateschema
>> [runserver_nostatic]
>>     runserver
>> [services]
>>     upgradeservices
>> [sessions]
>>     clearsessions
>> [sitemaps]
>>     ping_google
>> [staticfiles]
>>     collectstatic
>>     findstatic
>> [tastypie]
>>     backfill_api_keys
>> ==1920513== Invalid free() / delete / delete[] / realloc()
>> ==1920513==    at 0x4847669: operator delete(void*) (vg_replace_malloc.c:923)
>> ==1920513==    by 0x4C194B4: __run_exit_handlers (in /usr/lib64/libc.so.6)
>> ==1920513==    by 0x4C1962F: exit (in /usr/lib64/libc.so.6)
>> ==1920513==    by 0x4C01EB6: (below main) (in /usr/lib64/libc.so.6)
>> ==1920513==  Address 0x769a4f0 is 0 bytes inside a block of size 17 free'd
>> ==1920513==  Block was alloc'd at
>> ==1920513==    at 0x4844FF5: operator new(unsigned long) (vg_replace_malloc.c:422)
>> ==1920513==    by 0xD6C19C6: ??? (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD45B653: ??? (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD45C665: ??? (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0x400A1AD: call_init (dl-init.c:70)
>> ==1920513==    by 0x400A1AD: call_init (dl-init.c:26)
>> ==1920513==    by 0x400A29B: _dl_init (dl-init.c:117)
>> ==1920513==    by 0x4D57F64: _dl_catch_exception (in /usr/lib64/libc.so.6)
>> ==1920513==    by 0x4010CBD: dl_open_worker (dl-open.c:803)
>> ==1920513==    by 0x4D57F07: _dl_catch_exception (in /usr/lib64/libc.so.6)
>> ==1920513==    by 0x401104E: _dl_open (dl-open.c:879)
>> ==1920513==    by 0x4C5D86B: dlopen_doit (in /usr/lib64/libc.so.6)
>> ==1920513==
>> ==1920513== Invalid read of size 4
>> ==1920513==    at 0x11166C0D: ??? (in /usr/proj81/lib/libproj.so.22.1.1)
>> ==1920513==  Address 0x53444b8 is 8 bytes inside a block of size 24 free'd
>> ==1920513==    by 0xD5273BE: osgeo::proj::crs::GeographicCRS::create(osgeo::proj::util::PropertyMap const&, std::shared_ptr<osgeo::proj::datum::GeodeticReferenceFrame> const&, std::shared_ptr<osgeo::proj::datum::DatumEnsemble> const&, dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::cs::EllipsoidalCS> > const&) (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD527821: osgeo::proj::crs::GeographicCRS::create(osgeo::proj::util::PropertyMap const&, dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::datum::GeodeticReferenceFrame> > const&, dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::cs::EllipsoidalCS> > const&) (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD45B611: ??? (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==
>> ==1920513==    at 0x11166B5D: ??? (in /usr/proj81/lib/libproj.so.22.1.1)
>> ==1920513==  Address 0x51dbfe8 is 8 bytes inside a block of size 24 free'd
>> ==1920513==    by 0xD51DD72: osgeo::proj::crs::GeodeticCRS::create(osgeo::proj::util::PropertyMap const&, std::shared_ptr<osgeo::proj::datum::GeodeticReferenceFrame> const&, std::shared_ptr<osgeo::proj::datum::DatumEnsemble> const&, dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::cs::CartesianCS> > const&) (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD51E001: osgeo::proj::crs::GeodeticCRS::create(osgeo::proj::util::PropertyMap const&, dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::datum::GeodeticReferenceFrame> > const&, dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::cs::CartesianCS> > const&) (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD45B259: ??? (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==
>> ==1920513==    at 0x1116694D: ??? (in /usr/proj81/lib/libproj.so.22.1.1)
>> ==1920513==  Address 0x6f97b38 is 8 bytes inside a block of size 24 free'd
>> ==1920513==    by 0xD552BBB: osgeo::proj::datum::GeodeticReferenceFrame::create(osgeo::proj::util::PropertyMap const&, dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::datum::Ellipsoid> > const&, osgeo::proj::util::optional<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > const&, dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::datum::PrimeMeridian> > const&) (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD45B1C8: ??? (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==
>> ==1920513==    at 0x1116682D: ??? (in /usr/proj81/lib/libproj.so.22.1.1)
>> ==1920513==  Address 0x6ffbce8 is 8 bytes inside a block of size 24 free'd
>> ==1920513==    by 0xD5545C8: osgeo::proj::datum::Ellipsoid::createFlattenedSphere(osgeo::proj::util::PropertyMap const&, osgeo::proj::common::Length const&, osgeo::proj::common::Scale const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD45B022: ??? (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==
>> ==1920513==    at 0x11166AAD: ??? (in /usr/proj81/lib/libproj.so.22.1.1)
>> ==1920513==  Address 0x50d9d58 is 8 bytes inside a block of size 24 free'd
>> ==1920513==    by 0xD552D55: osgeo::proj::datum::PrimeMeridian::create(osgeo::proj::util::PropertyMap const&, osgeo::proj::common::Angle const&) (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD45AE71: ??? (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==
>> ==1920513== Invalid read of size 8
>> ==1920513==    at 0xD506BB5: osgeo::proj::common::UnitOfMeasure::~UnitOfMeasure() (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==  Address 0x52a51a0 is 80 bytes inside a block of size 112 free'd
>> ==1920513==    by 0xD506BF7: osgeo::proj::common::UnitOfMeasure::~UnitOfMeasure() (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD5068B3: osgeo::proj::common::UnitOfMeasure::UnitOfMeasure(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, double, osgeo::proj::common::UnitOfMeasure::Type, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD459C20: ??? (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==
>> ==1920513==    at 0xD506BC9: osgeo::proj::common::UnitOfMeasure::~UnitOfMeasure() (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==  Address 0x52a5180 is 48 bytes inside a block of size 112 free'd
>> ==1920513==
>> ==1920513==    at 0xD506BDD: osgeo::proj::common::UnitOfMeasure::~UnitOfMeasure() (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==  Address 0x52a5150 is 0 bytes inside a block of size 112 free'd
>> ==1920513==
>> ==1920513==    by 0xD506BEF: osgeo::proj::common::UnitOfMeasure::~UnitOfMeasure() (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==  Address 0x52a5200 is 0 bytes inside a block of size 27 free'd
>> ==1920513==    by 0xD6C1E21: ??? (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD5068D2: osgeo::proj::common::UnitOfMeasure::UnitOfMeasure(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, double, osgeo::proj::common::UnitOfMeasure::Type, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==
>> ==1920513==
>> ==1920513==    at 0xD4FC12C: osgeo::proj::util::BaseObject::~BaseObject() (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==  Address 0x4fbd2c8 is 8 bytes inside a block of size 16 free'd
>> ==1920513==    by 0xD50688E: osgeo::proj::common::UnitOfMeasure::UnitOfMeasure(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, double, osgeo::proj::common::UnitOfMeasure::Type, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==
>> ==1920513==    at 0x111669FD: ??? (in /usr/proj81/lib/libproj.so.22.1.1)
>> ==1920513==  Address 0x7672b88 is 8 bytes inside a block of size 24 free'd
>> ==1920513==    by 0xD50A82E: osgeo::proj::metadata::Extent::create(osgeo::proj::util::optional<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > const&, std::vector<dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::metadata::GeographicExtent> >, std::allocator<dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::metadata::GeographicExtent> > > > const&, std::vector<dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::metadata::VerticalExtent> >, std::allocator<dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::metadata::VerticalExtent> > > > const&, std::vector<dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::metadata::TemporalExtent> >, std::allocator<dropbox::oxygen::nn<std::shared_ptr<osgeo::proj::metadata::TemporalExtent> > > > const&) (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD50B50D: osgeo::proj::metadata::Extent::createFromBBOX(double, double, double, double, osgeo::proj::util::optional<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > const&) (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==    by 0xD4581A3: ??? (in /usr/proj92/lib64/libproj.so.25.9.2.1)
>> ==1920513==
>> ==1920513==
>> ==1920513== HEAP SUMMARY:
>> ==1920513==     in use at exit: 33,404,131 bytes in 289,625 blocks
>> ==1920513==   total heap usage: 5,364,478 allocs, 5,074,892 frees, 603,905,211 bytes allocated
>> ==1920513==
>> ==1920513== LEAK SUMMARY:
>> ==1920513==    definitely lost: 19,848 bytes in 186 blocks
>> ==1920513==    indirectly lost: 46,487 bytes in 820 blocks
>> ==1920513==      possibly lost: 7,405,431 bytes in 80,304 blocks
>> ==1920513==    still reachable: 25,932,365 bytes in 208,315 blocks
>> ==1920513==                       of which reachable via heuristic:
>> ==1920513==                         stdstring          : 32,406 bytes in 649 blocks
>> ==1920513==                         length64           : 2,308,144 bytes in 23,524 blocks
>> ==1920513==         suppressed: 0 bytes in 0 blocks
>> ==1920513== Rerun with --leak-check=full to see details of leaked memory
>> ==1920513==
>> ==1920513== For lists of detected and suppressed errors, rerun with: -s
>> ==1920513== ERROR SUMMARY: 154 errors from 13 contexts (suppressed: 0 from 0)
>> I think the cause of the segmentation fault is an incompatibility of the projXX libraries.
>> I tried to force just one version of proj to be installed, but I didn't succeed. libspatialite50 requires both proj82 and proj92.
>> [root at vmi1397095 lib]# dnf repoquery --requires libspatialite50
>> Last metadata expiration check: 2:33:06 ago on Tue Aug 29 07:48:15 2023.
>> /sbin/ldconfig
>> geos310 >= 3.10.3
>> geos311 >= 3.11.2
>> geos312 >= 3.12.0
>> libc.so.6(GLIBC_2.34)(64bit)
>> libfreexl.so.1()(64bit)
>> libgeos_c.so.1()(64bit)
>> libm.so.6()(64bit)
>> libm.so.6(GLIBC_2.2.5)(64bit)
>> libm.so.6(GLIBC_2.29)(64bit)
>> libminizip.so.3.0()(64bit)
>> libproj.so.22()(64bit)
>> libproj.so.25()(64bit)
>> librttopo.so.1()(64bit)
>> libsqlite3.so.0()(64bit)
>> libxml2.so.2()(64bit)
>> libxml2.so.2(LIBXML2_2.4.30)(64bit)
>> libxml2.so.2(LIBXML2_2.5.8)(64bit)
>> libxml2.so.2(LIBXML2_2.6.0)(64bit)
>> libxml2.so.2(LIBXML2_2.6.2)(64bit)
>> libz.so.1()(64bit)
>> libz.so.1(ZLIB_1.2.0)(64bit)
>> proj82 >= 8.2.1
>> proj92 >= 9.2.1
>> rtld(GNU_HASH)
>> If I try to uninstall proj81 or proj82... all postgis and gdal libraries are uninstalled :(
>> [root at geonode lib]# dnf remove proj81
>> Dependencies resolved.
>>  Package                                   Architecture         Version                              Repository                  Size
>> Removing:
>>  proj81                                    x86_64               8.1.1-1.rhel9                        @pgdg-common                11 M
>> Removing dependent packages:
>>  gdal35                                    x86_64               3.5.3-6PGDG.rhel9                    @pgdg-common               866 k
>>  gdal35-devel                              x86_64               3.5.3-6PGDG.rhel9                    @pgdg-common               1.2 M
>>  gdal35-java                               x86_64               3.5.3-6PGDG.rhel9                    @pgdg-common               1.8 M
>>  postgis33_13                              x86_64               3.3.3-1.rhel9                        @pgdg13                     43 M
>> Removing unused dependencies:
>>  SFCGAL                                    x86_64               1.4.1-11.rhel9                       @pgdg-common                32 k
>>  SFCGAL-libs                               x86_64               1.4.1-11.rhel9                       @pgdg-common               6.8 M
>>  SuperLU                                   x86_64               5.3.0-2.el9                          @epel                      475 k
>>  armadillo                                 x86_64               10.8.2-4.el9                         @epel                      102 k
>>  arpack                                    x86_64               3.8.0-4.el9                          @epel                      640 k
>>  blas                                      x86_64               3.9.0-8.el9                          @appstream                 1.1 M
>>  boost-serialization                       x86_64               1.75.0-8.el9                         @appstream                 454 k
>>  cfitsio                                   x86_64               4.1.0-1.el9                          @epel                      1.8 M
>>  flexiblas                                 x86_64               3.0.4-8.el9                          @appstream                  68 k
>>  flexiblas-netlib                          x86_64               3.0.4-8.el9                          @appstream                  11 M
>>  flexiblas-netlib64                        x86_64               3.0.4-8.el9                          @crb                        11 M
>>  flexiblas-openblas-openmp                 x86_64               3.0.4-8.el9                          @appstream                  39 k
>>  flexiblas-openblas-openmp64               x86_64               3.0.4-8.el9                          @crb                        40 k
>>  freexl                                    x86_64               1.0.6-15.el9                         @epel                       69 k
>>  gdal35-libs                               x86_64               3.5.3-6PGDG.rhel9                    @pgdg-common                24 M
>>  geos311                                   x86_64               3.11.2-1.rhel9                       @pgdg-common               3.1 M
>>  geos312                                   x86_64               3.12.0-1PGDG.rhel9                   @pgdg-common               3.5 M
>>  gmp-c++                                   x86_64               1:6.2.0-10.el9                       @appstream                  32 k
>>  gpsbabel                                  x86_64               1.8.0-1.rhel9                        @pgdg-common               1.9 M
>>  hdf-libs                                  x86_64               4.2.15-7.el9                         @epel                      689 k
>>  hdf5                                      x86_64               1.12.1-7.el9.1                       @epel                      8.2 M
>>  javapackages-tools                        noarch               6.0.0-4.el9                          @appstream                  63 k
>>  lapack                                    x86_64               3.9.0-8.el9                          @appstream                  15 M
>>  libaec                                    x86_64               1.0.6-1.el9                          @epel                      119 k
>>  libgeotiff16                              x86_64               1.6.0-6.rhel9                        @pgdg-common               353 k
>>  libgeotiff16-devel                        x86_64               1.6.0-6.rhel9                        @pgdg-common               132 k
>>  libgfortran                               x86_64               11.3.1-4.3.el9.alma                  @baseos                    2.8 M
>>  libgta                                    x86_64               1.2.1-7.el9                          @epel                       70 k
>>  libqhull_r                                x86_64               1:7.2.1-9.el9                        @crb                       388 k
>>  libquadmath                               x86_64               11.3.1-4.3.el9.alma                  @baseos                    330 k
>>  librttopo                                 x86_64               1.1.0-2.rhel9                        @pgdg-common               623 k
>>  libspatialite50                           x86_64               5.1.0-1PGDG.rhel9                    @pgdg-common                20 M
>>  libspatialite50-devel                     x86_64               5.1.0-1PGDG.rhel9                    @pgdg-common               773 k
>>  libtiff-devel                             x86_64               4.4.0-8.el9_2                        @appstream                 1.7 M
>>  lz4                                       x86_64               1.9.3-5.el9                          @baseos                    113 k
>>  minizip                                   x86_64               3.0.2-6.el9                          @epel                      167 k
>>  netcdf                                    x86_64               4.8.1-2.el9                          @epel                      2.1 M
>>  ogdi41                                    x86_64               4.1.0-3.rhel9                        @pgdg-common               860 k
>>  openblas                                  x86_64               0.3.21-2.el9                         @appstream                  82 k
>>  openblas-openmp                           x86_64               0.3.21-2.el9                         @appstream                  39 M
>>  openblas-openmp64                         x86_64               0.3.21-2.el9                         @crb                        39 M
>>  openblas-serial                           x86_64               0.3.21-2.el9                         @appstream                  38 M
>>  pcre2-utf16                               x86_64               10.40-2.el9                          @appstream                 571 k
>>  postgresql13-contrib                      x86_64               13.12-1PGDG.rhel9                    @pgdg13                    2.3 M
>>  proj90                                    x86_64               9.0.1-1.rhel9                        @pgdg-common                13 M
>>  proj92                                    x86_64               9.2.1-1PGDG.rhel9                    @pgdg-common                13 M
>>  qt5-qtbase                                x86_64               5.15.3-1.el9                         @appstream                  10 M
>>  qt5-qtbase-common                         noarch               5.15.3-1.el9                         @appstream                  75
>>  shapelib                                  x86_64               1.5.0-12.el9                         @epel                      191 k
>>  sqlite                                    x86_64               3.34.1-6.el9_1                       @appstream                 1.5 M
>>  unixODBC                                  x86_64               2.3.9-4.el9                          @appstream                 1.4 M
>>  xerces-c                                  x86_64               3.2.3-5.el9                          @epel                      3.6 M
>> Transaction Summary
>> Remove  57 Packages
>> Freed space: 340 M
>> I also tried to manually remove one of the projXX, but in that case the system dependendies are broken and the scripts fails with an error that the libraries are not available.
>> I feel this problem is something recurrent for people dealing with gdal libraries, but I don't know if there is a workaround. Do you know a workaround to avoid the segmentation fault?
>> I also tried to upgrade to python 3.11 but then another error rises about regular expression syntax when running python manage.py:
>> (geonode-4.1.x) [geonode at geonode geonode-src]$ python3 manage.py
>> Traceback (most recent call last):
>>   File "/home/geonode/geonode-src/manage.py", line 29, in <module>
>>     execute_from_command_line(sys.argv)
>>   File "/home/geonode/venv/geonode-4.1.x/lib64/python3.11/site-packages/django/core/management/__init__.py", line 419, in execute_from_command_line
>>     utility.execute()
>>   File "/home/geonode/venv/geonode-4.1.x/lib64/python3.11/site-packages/django/core/management/__init__.py", line 395, in execute
>>     django.setup()
>>   File "/home/geonode/venv/geonode-4.1.x/lib64/python3.11/site-packages/django/__init__.py", line 24, in setup
>>     apps.populate(settings.INSTALLED_APPS)
>>   File "/home/geonode/venv/geonode-4.1.x/lib64/python3.11/site-packages/django/apps/registry.py", line 122, in populate
>>     app_config.ready()
>>   File "/home/geonode/geonode-src/geonode/harvesting/apps.py", line 31, in ready
>>     from geonode.urls import urlpatterns
>>   File "/home/geonode/geonode-src/geonode/urls.py", line 33, in <module>
>>     import geonode.proxy.urls
>>   File "/home/geonode/geonode-src/geonode/proxy/urls.py", line 22, in <module>
>>     from . import views
>>   File "/home/geonode/geonode-src/geonode/proxy/views.py", line 59, in <module>
>>     ows_regexp = re.compile(r"^(?i)(version)=(\d\.\d\.\d)(?i)&(?i)request=(?i)(GetCapabilities)&(?i)service=(?i)(\w\w\w)$")
>>   File "/usr/lib64/python3.11/re/__init__.py", line 227, in compile
>>     return _compile(pattern, flags)
>>   File "/usr/lib64/python3.11/re/__init__.py", line 294, in _compile
>>     p = _compiler.compile(pattern, flags)
>>   File "/usr/lib64/python3.11/re/_compiler.py", line 743, in compile
>>     p = _parser.parse(p, flags)
>>   File "/usr/lib64/python3.11/re/_parser.py", line 980, in parse
>>     p = _parse_sub(source, state, flags & SRE_FLAG_VERBOSE, 0)
>>   File "/usr/lib64/python3.11/re/_parser.py", line 455, in _parse_sub
>>     itemsappend(_parse(source, state, verbose, nested + 1,
>>   File "/usr/lib64/python3.11/re/_parser.py", line 841, in _parse
>>     raise source.error('global flags not at the start '
>> re.error: global flags not at the start of the expression at position 1
>> Segmentation fault (core dumped)
>> Regards.
>> Orestes, member of Arxiu
>> Arxiu Històric del Poblenou
>> Torre de les Aigües del Besòs, plaça Ramon Calsina 1
>> www.arxiuhistoricpoblenou.cat <http://www.arxiuhistoricpoblenou.cat/> - info at arxiuhistoricpoblenou.cat <mailto:info at arxiuhistoricpoblenou.cat>
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Dott. Giovanni Allegri
> Technical Lead / Project Manager
> GeoSolutions Group
> phone: +39 0584 962313
> cell:      +39 345 2815774
> fax:      +39 0584 1660272
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20230831/b40d712f/attachment-0001.htm>
More information about the geonode-users mailing list
