[GeoNode-users] Geonode Layers cannot load!
Γιώργος Πούλος gpoul2000 at hotmail.com
Thu Feb 2 09:02:13 PST 2023
Dear users
My geonode application (ubuntu 20.4 (full installation) has no more access to layers, but has access to maps!
>From geonode layer when I click to see a layer I get a 502 Bad Gateway!
>From geonode map when I click to see a map all are OK!
I find it strange because the layers are loading in the maps without problem!
I cannot understand this, so here are the logs from nginx, uwsgi and geoserver!
nginx/error.log
[error] 1101#1101: *19637 upstream prematurely closed connection while reading response header from upstream, client: xx.xx.xx.xx, server: 127.0.0.1, request: "GET /layers/alt_tel_DP022_20230209:geonode:alt_tel_DP022_20230209 HTTP/2.0", upstream: "uwsgi://127.0.0.1:8000", host: "myhost:8443", referrer: https://myhost:8443/layers/?limit=5&offset=0
uwsgi/app/geonode.log
[pid: 47128|app: 0|req: 71/741] xx.xx.xx.xxx () {50 vars in 955 bytes} [Thu Feb  2 16:15:00 2023] GET /api/categories/?type=layer => generated 17130 bytes in 900 msecs (HTTP/2.0 200) 9 headers in 340 bytes (1 switches on core 0)
Thu Feb  2 16:15:04 2023 - !!! uWSGI process 46036 got Segmentation Fault !!!
Thu Feb  2 16:15:04 2023 - *** backtrace of 46036 ***
/usr/bin/uwsgi(uwsgi_backtrace+0x33) [0x55b23d1a5d83]
/usr/bin/uwsgi(uwsgi_segfault+0x27) [0x55b23d1a6197]
/lib/x86_64-linux-gnu/libc.so.6(+0x430c0) [0x7f8bda5c60c0]
*** end of backtrace ***
double free or corruption (out)
/geoserver_logs/geoserver.log
2023-02-02 16:26:38,428 WARN [geoserver.geofence] - No source IP address found
2023-02-02 16:26:38,428 WARN [geoserver.geofence] - Error retrieving source address with Spring Request: No thread-bound request found: Are you referring to request attributes outside of an actual web request, or processing a request outside of the originally receiving thread? If you are actually operating within a web request and still receive this message, your code is probably running outside of DispatcherServlet: In this case, use RequestContextListener or RequestContextFilter to expose the current request.
Πούλος Γιώργος
t 6970115279, mail: gpoul2000 at hotmail.com
P Please consider the environment before printing this document
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20230202/b61d7760/attachment.htm>
More information about the geonode-users mailing list
