[GeoNode-users] WMTS
Alessio Fabiani alessio.fabiani at geosolutionsgroup.com
Wed Feb 15 06:06:54 PST 2023
Dear Jan,
unless you have some development resources to extend the GeoNode Harvesters
and Remote Services, probably the easiest way currently would be to create
a WMTS Cascade store on GeoServer and then allow GeoNode to update the
Datasets from it.
On Wed, Feb 15, 2023 at 2:15 PM Jan Willem van der Lichte <
jwgvanderlichte at gmail.com> wrote:
> Hi list,
> Is there a possibility to use WMTS-services.
> In the Netherlands we have PDOK which produces a lot of WMTS-services, I
> cna't find a way to use/harvest them in Geonode
> Thanks!
> Met groet,
> Jan Willem
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20230215/6115f2df/attachment.htm>
More information about the geonode-users mailing list
