[GeoNode-users] Geonode Harvesters
Kabatha Patrick kpparto at gmail.com
Thu Sep 28 11:25:15 PDT 2023
Dear Giovanni,
It seems to work, following your prescribed process, though
inconsistently for me. I need to keep testing/learning the process.
[image: image.png]
Thanks a lot.
Cheers!
On Tue, Sep 26, 2023 at 11:19 AM Giovanni Allegri <
giovanni.allegri at geosolutionsgroup.com> wrote:
> I've done a test with the development demo, harvesting the stable demo,
> and it looks almost good.
>    1. Created the harvester (with scheduling disabled)
>    2. Selected the harvester and executed the action "Perform harvesting
>    on selected harvesters"
>    3. An Async session has started with type
>    "disocer-harvestable-resources".
> The problem is that it looks stalled after a while. The ingested
> resources do not increase and the session is still marked "ongoing". See
> image below.
> We will have to investigate...
> [image: image.png]
> Giovanni
> On Mon, Sep 25, 2023 at 8:38 PM Kabatha Patrick via geonode-users <
> geonode-users at lists.osgeo.org> wrote:
>> Hi Alessio,
>> No. I don't think so.
>> I simply installed geonode using the basic installation procedure
>> <https://training.geonode.geosolutionsgroup.com/master/GN3/basic_install/index.html>.
>> Configured the .env_local files and nginx appropriately and now running in
>> production mode.
>> On Mon, Sep 25, 2023 at 10:28 AM Alessio Fabiani <
>> alessio.fabiani at geosolutionsgroup.com> wrote:
>>> Are you running GeoNode in ASYNC mode?
>>> On Sun, Sep 24, 2023 at 6:45 PM Kabatha Patrick via geonode-users <
>>>> Hi there,
>>>> Anyone who has successfully set-up a geonode harvester. Everything
>>>> seems fine here:
>>>> [image: image.png]
>>>> But I don't get the list of harvestable resources as explained in this
>>>> tutorial
>>>> <https://training.geonode.geosolutionsgroup.com/master/GN2/HARVESTERS/index.html>.
>>>> Is there configurations that need to be done on the remote server (i.e.
>>>> where resources are being harvested from).
>>>> Anyone who has successfully set up the harvesting session?
>>>> Thanks,
>>>> GIS Analyst
>>>> Geography & Ecology.
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Regards,
>>> Alessio Fabiani
>>> GeoServer Professional Services from the experts!
>>> Visit http://bit.ly/gs-services-us for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions Group
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39  331 6233686
>>> https://www.geosolutionsgroup.com/
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
>> GIS Analyst
> Dott. Giovanni Allegri
> Technical Lead / Project Manager
> GeoSolutions Group
> cell:     +39 345 2815774
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GIS Analyst
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20230928/8cd34ad7/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20230928/8cd34ad7/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20230928/8cd34ad7/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20230928/8cd34ad7/attachment-0005.png>
More information about the geonode-users mailing list
