[Geoprisma-dev] GeoNamesSearchCombo wrong LatLng in GP
Yves Moisan yves.moisan at boreal-is.com
Mon Nov 23 08:30:29 EST 2009
Le vendredi 20 novembre 2009 à 16:14 -0500, Alexandre Dube a écrit :
> Hey,
>   I don't know why (yet), but the GeoNamesSearchCombo widget, when used
> in GeoPrisma, doesn't zoom the the correct location.  See the difference
> between the two samples below :
> [1]
> http://dev.geoext.org/ux/GeoNamesSearchCombo/examples/GeoNamesSearchComboExample.html
<script type="text/javascript"
src="http://extjs.cachefly.net/builds/ext-cdn-771.js"></script>
        <link rel="stylesheet" type="text/css" href="http://extjs.cachefly.net/ext-2.2.1/resources/css/ext-all.css" />
        <link rel="stylesheet" type="text/css" href="http://extjs.cachefly.net/ext-2.2.1/examples/shared/examples.css" />
        <script src="http://openlayers.org/api/2.8/OpenLayers.js"></script>
> [2] http://www.geoprisma.org/samples/geoextux/geonamessearchcombo/
We use Ext 3.0 and trunk of the other libs.  Maybe you could try with
the same JS libraries used on dev.geoext ?
Yves
More information about the Geoprisma-dev mailing list
