[Geoprisma-dev] GeoNamesSearchCombo wrong LatLng in GP
Alexandre Dube adube at mapgears.com
Mon Nov 23 09:24:52 EST 2009
Yves,
  I tried what you proposed but it didn't solved the issue.  I made a
text.html file out of what GeoPrisma outputs to try to find out what's
wrong.  See the attached file and simply put it in :
  I'll dig more and report back.  Thanks for your help,
Alexandre
Yves Moisan wrote:
> Le vendredi 20 novembre 2009 à 16:14 -0500, Alexandre Dube a écrit :
>> Hey,
>>   I don't know why (yet), but the GeoNamesSearchCombo widget, when used
>> in GeoPrisma, doesn't zoom the the correct location.  See the difference
>> between the two samples below :
>> [1]
>> http://dev.geoext.org/ux/GeoNamesSearchCombo/examples/GeoNamesSearchComboExample.html
> <script type="text/javascript"
> src="http://extjs.cachefly.net/builds/ext-cdn-771.js"></script>
>         <link rel="stylesheet" type="text/css" href="http://extjs.cachefly.net/ext-2.2.1/resources/css/ext-all.css" />
>         <link rel="stylesheet" type="text/css" href="http://extjs.cachefly.net/ext-2.2.1/examples/shared/examples.css" />
>         <script src="http://openlayers.org/api/2.8/OpenLayers.js"></script>
>> [2] http://www.geoprisma.org/samples/geoextux/geonamessearchcombo/
> We use Ext 3.0 and trunk of the other libs.  Maybe you could try with
> the same JS libraries used on dev.geoext ?
> Yves
Alexandre Dubé
Mapgears
www.mapgears.com
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/geoprisma-dev/attachments/20091123/6d6f440c/test.tar.gz
More information about the Geoprisma-dev mailing list
