[Geoprisma-dev] Where do we build the widget doc ?
Yves Moisan yves.moisan at boreal-is.com
Mon Nov 23 15:11:50 EST 2009
Le lundi 23 novembre 2009 à 15:02 -0500, Alexandre Dube a écrit :
> Yves Moisan wrote:
> > If that works, you're good to go
> > your-machine: .../geoprisma/trunk/docs$ sphinx-build -b html
> > source/ ../dist/build/
> > Yves
> I think I found why it doesn't work :
> When I type "sphinx-build 2>&1" in a shell, it finds the Sphinx version,
> but I use FGS (which has its own environment)... When setting the FGS
> environment and typing the command again, I get the error...
I never use an FGS environment, except for launching Apache.  Open up a
new terminal.  I've been bitten a few times :-)
Yves
More information about the Geoprisma-dev mailing list
