[Geoprisma-dev] Where do we build the widget doc ?
Alexandre Dube adube at mapgears.com
Mon Nov 23 15:34:06 EST 2009
Yves Moisan wrote:
> I never use an FGS environment, except for launching Apache.  Open up a
> new terminal.  I've been bitten a few times :-)
> Yves
Building the doc works in a new terminal, but "samples" and "widgets"
are not included.  That is because the script comes from the site php
and is executable only that way.  In it, it temporarily copies the .rst
files from the widgets directory....
So unless Sphinx is included in FGS or the script is moved / copied to
the make.bat script, there's nothing much to do...
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
