[Geoprisma-dev] Where do we build the widget doc ?
Alexandre Dube adube at mapgears.com
Tue Nov 24 11:27:22 EST 2009
Yves Moisan wrote:
> I would personally try to use the default Ubuntu env if you can.  FGS's
> footprint is a bit bothersome IMO.  That's why I keep it on a "per
> shell" basis.
> HTH,
> Yves
OK, I'll try that then.  Thanks.
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
