[Geoprisma-dev] Legend Panel - Scrollbar
Julien-Samuel Lacroix jlacroix at mapgears.com
Fri Nov 27 11:17:38 EST 2009
I didn't test the LegendPanel with a lot of layers, but I would have
assumed that it would have worked out of the box. There's probably a
small glitch in the sample1 xslt template. Can you reproduce the issue
with one of the GeoPrisma sample? If so, please open a ticket in trac
with a small description of how to reproduce the problem.
Julien
louis.rocheleau wrote:
> Hi Jean-Samuel,
> actually I do not develop GP, I am a user of it. I copied the legend panel
> from Sample1, as Yves recommended to me. I then realized that when I load
> many layers, the scrollbar does not come. Did you test to see if the
> scrollbar is coming when you put many layers ?
> Also, you mention that "it may be because [I] put the Panel inside another
> Panel...", is there another way to display a legend ?
> Regards
> Louis
> Boréalis
> Julien-Samuel Lacroix wrote:
>> Hi,
>> I would have think that the scrollbar would be automatically there. It
>> may be because you put the Panel inside another Panel...
>> Does that help?
>> http://www.extjs.com/forum/showthread.php?t=42912
>> http://www.yui-ext.com/forum/showthread.php?t=56199
>> Julien
>>> Hello again,
>>> I have configured a Legend Panel for the layers on a GP map. It goes all
>>> fine using the Sample1 example. My only concern is when you reach a
>>> certain
>>> number of elements in the Legend Panel, you can't see all the
>>> information,
>>> as there is no scroll bar. Is there any development on having such a tool
>>> I am not sure but would the layer tree act the same if too many layers
>>> were
>>> defined ?
>>> Thanks
>>> Louis
>> Mapgears
>> http://www.mapgears.com/
>> Geoprisma-dev mailing list
>> Geoprisma-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Mapgears
More information about the Geoprisma-dev mailing list
