[Geoprisma-dev] Legend Panel - Scrollbar
louis.rocheleau louis.rocheleau at boreal-is.com
Fri Nov 27 11:44:20 EST 2009
Hi Julien-Samuel,
Unfortunately I will not have time to reproduce the error with the GeoPrisma
samples. I am currently in a mission out of the country. Though let's keep
in touch.
Cheers
Louis
Julien-Samuel Lacroix wrote:
> Hi,
> I didn't test the LegendPanel with a lot of layers, but I would have
> assumed that it would have worked out of the box. There's probably a
> small glitch in the sample1 xslt template. Can you reproduce the issue
> with one of the GeoPrisma sample? If so, please open a ticket in trac
> with a small description of how to reproduce the problem.
> Julien
> louis.rocheleau wrote:
>> Hi Jean-Samuel,
>> actually I do not develop GP, I am a user of it. I copied the legend
>> panel
>> from Sample1, as Yves recommended to me. I then realized that when I load
>> many layers, the scrollbar does not come. Did you test to see if the
>> scrollbar is coming when you put many layers ?
>> Also, you mention that "it may be because [I] put the Panel inside
>> another
>> Panel...", is there another way to display a legend ?
>> Regards
>> Louis
>> Boréalis
>>> Hi,
>>> I would have think that the scrollbar would be automatically there. It
>>> may be because you put the Panel inside another Panel...
>>> Does that help?
>>> http://www.extjs.com/forum/showthread.php?t=42912
>>> http://www.yui-ext.com/forum/showthread.php?t=56199
>>> Julien
>>>> Hello again,
>>>> I have configured a Legend Panel for the layers on a GP map. It goes
>>>> all
>>>> fine using the Sample1 example. My only concern is when you reach a
>>>> certain
>>>> number of elements in the Legend Panel, you can't see all the
>>>> information,
>>>> as there is no scroll bar. Is there any development on having such a
>>>> tool
>>>> I am not sure but would the layer tree act the same if too many layers
>>>> were
>>>> defined ?
>>>> Thanks
>>>> Louis
>>> Mapgears
>>> http://www.mapgears.com/
>>> Geoprisma-dev mailing list
>>> Geoprisma-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
> Mapgears
View this message in context: http://n3.nabble.com/Legend-Panel-Scrollbar-tp41268p42050.html
Sent from the GeoPrisma-dev mailing list archive at Nabble.com.
More information about the Geoprisma-dev mailing list
