[Geoprisma-dev] QueryOnClick - Clear button
Alexandre Dube adube at mapgears.com
Fri Oct 30 09:01:25 EDT 2009
Yves Moisan wrote:
> In that case, do we need a button at all ?  Maybe just a "clear marker"
> functionality should be added to queryonclick and called onDeactivate ?
> That would take care of the main visual ill side-effect of our current
> QueryOnClick.
Agreed.
> Do results need to be force-cleared if they are in a panel or hidden in
> a tab, since they are already cleared by a new query ?  Does anybody
> really need a "reset all" (that is marker and results) ?  I for one do
> not think so.
Then let's make the "partial-clear" our default behavior with the
possibility to set "none", "partial-clear" or "all" as an option.
Would that be ok ?
Alexandre
> What do others think ?
> Yves
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
