[Geoprisma-dev] QueryOnClick - Clear button
Yves Moisan yves.moisan at boreal-is.com
Fri Oct 30 14:16:28 EDT 2009
> Commited r690.
> Comments welcomed.  See the doc of the widget to see what's new.
> There's also a new QueryOnClick sample (with this widget only).
Works perfectly thank you !  Maybe it would be clearer to provide the
following in your switch case :
case "marker" that would be the default (instead of setting it to null)
IMO, it makes more sense to have a choice of (nothing, marker, all) than
(null, nothing, all) where 'null' really means 'marker'.
My 2 cents,
Yves
More information about the Geoprisma-dev mailing list
