[Geoprisma-dev] QueryOnClick - Clear button
Yves Moisan yves.moisan at boreal-is.com
Fri Oct 30 14:22:02 EDT 2009
> case "marker" that would be the default (instead of setting it to null)
Rather, I would *add* a 'marker' case and leave the default as is for
backwards compatibility with previous configuration files.  So both the
default (null) and marker would remove the marker.
Yves
More information about the Geoprisma-dev mailing list
