[Geoprisma-dev] QueryOnClick - Clear button
Alexandre Dube adube at mapgears.com
Fri Oct 30 15:22:47 EDT 2009
Yves Moisan wrote:
>> case "marker" that would be the default (instead of setting it to null)
> Rather, I would *add* a 'marker' case and leave the default as is for
> backwards compatibility with previous configuration files.  So both the
> default (null) and marker would remove the marker.
> Yves
Understood.
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
