[Geoprisma-dev] 'core' files not included by default
Alexandre Dube adube at mapgears.com
Wed Aug 11 13:59:57 EDT 2010
   In fact, that's the 'url' that is more important to know when
including .js core files.  So, knowing the 'widgets' url is normally not
enough (it could be a root url).  If we look at all samples, we'll see
that the core files are included by looking at the widget_url, then
../core.  That's not really right, but works if you made the 'client'
folder web visible for example and that the widget url is something like
: geoprisma/client/widgets.
   Well, I don't think there's a good workaround for this one in the
end.  Unless we all agree that there should be a 'setCoreDir' and
'setCoreUrl', there is no solution for this issue.
   Comments ?
Regards,
Alexandre
On 10-08-11 01:50 PM, Alexandre Dube wrote:
> Hi devs,
>   As you may have already noticed a long time ago, you must set the
> 'widget_dir' and 'template_dir' parameters inside SettingImpl to let
> GeoPrisma know where they are.  That's not the case for the 'core'
> directory.  There is no method for this one.  So, all supposed
> GeoPrisma 'core' files must be manually included inside the
> template.xslt file every time (see resultextgrid for a good example).
>   That's pretty annoying.  Here's what I propose : include these files
> inside Globals.xslt, in the printAllWidgetSources method.  In order to
> do this, we must know the 'core' directory.  We could do :
>   1) set the 'core' directory at the same time inside the
> 'setWidgetDir' method, knowing it's on the same 'level' and that it
> will never move.  That should avoid to have to modify each common.php
> file to add a new "setCoreDir" method call.
>   2) or, we could say that there is no need to set the 'core' at all
> since by using the 'widgets' location, we can assume where it is.  So
> we would do a 'getWidgetDir' then back one dir then 'core'.
> Any comments ?  Objections on including the core files inside
> Globals.xslt ?
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
