[Geoprisma-dev] isAuthorized method change
Alexandre Dube adube at mapgears.com
Tue Aug 17 11:56:40 EDT 2010
See the proposed patch :
http://trac.osgeo.org/geoprisma/attachment/ticket/132/patch-geoprisma-132-r862-A0.diff
Regards,
Alexandre
On 10-08-17 11:52 AM, Alexandre Dube wrote:
> Well, when you think about it it's not that big of a deal.  It's just
> "changing" a string property for an "object", so I really guess it's
> okay since it's not breaking anything.  If no one disagrees, I'd go
> ahead and commit.
> I made all according changes all over GeoPrisma code.  If you use
> user-made php scripts that are using the org_geoprisma_acl_ACL
> 'isAuthorized' method, you need to give the method a
> org_geoprisma_resource_Resource instead of its name.
> Regards,
> Alexandre
> On 10-08-17 10:39 AM, Alexandre Dube wrote:
>> Hi devs,
>>   I need to do a major change in the core of geoprisma and would like
>> to know if it's okay with everyone.  I need to change the
>> 'isAuthorized' method of the acl object of geoprisma (not the actual
>> 'isAuthorized method of acl objects).
>>   I need the method to receive the org_geoprisma_resource_Resource
>> object instead of its name directly.  The details are in this ticket
>> [1].  It would be a rare urgent question since it's a 'critical'
>> ticket (could have been 'blocker') so if possible I'd like to have
>> quick answers, please.
>> Regards,
>> [1] http://trac.osgeo.org/geoprisma/ticket/132
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
