[Geoprisma-dev] maxextent on OSM
Alexandre Dube adube at mapgears.com
Tue Aug 31 11:02:12 EDT 2010
   Could you please create a patch containing your changes showing the
issue and attach it to this thread ?
Alexandre
On 10-08-30 04:04 PM, Yves Moisan wrote:
>  Hi All,
> I was reported a bug that using OSM as a baselayer did not allow
> zoomTo maxextent to work.  I just tried changing the maxextent on the
> GYMO example on geoprisma.org (e.g.
> -8825183.54329388,5415932.48054272,-8809006.11468559,5432908.21775132)
> and it works fine on the Google layers.  If I draw the OSM layer first
> and reorder it in the layertree too, the map does not zoom in to the
> maxextent I defined.
> Is it the way we manage OSM in GP or is it a known OpenLayers issue ?
> TIA,
> Yves
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
