[Geoprisma-dev] maxextent on OSM
Yves Moisan yves.moisan at boreal-is.com
Tue Aug 31 15:09:33 EDT 2010
  Le 2010-08-31 13:22, Alexandre Dube a écrit :
> Yves,
> Ok, it would seem that defining a 'maxExtent' option to the
> OpenLayers.Map object automatically set the maxExtent of the layers
> added, but not the XYZ (OSM) ones.  They are automatically calculated
> and ignore the one from the map.
> I guess that adding the 'maxExtent' property to the layer should do
> the trick (currently not supported in GeoPrisma), but how come it
> doesn't I don't know.  This question should be asked to
> OpenLayers-Users ML I guess.
Alexandre,
I thought about going to an OL list but the examples I checked from the
OL examples web site worked for OSM.  In fact they are often doing a
getBounds apparently.
Thanx
Yves
> Regards,
> Alexandre
> On 10-08-31 12:09 PM, Yves Moisan wrote:
>>  Le 2010-08-31 11:02, Alexandre Dube a écrit :
>>> Hi,
>>>   Could you please create a patch containing your changes showing
>>> the issue and attach it to this thread ?
>> Just replace :
>> <!--maxextent>-20037508.34,-20037508.34,20037508.34,20037508.34</maxextent-->
>> <maxextent>11548635,-5889094,18604187,-597430</maxextent>
>> in config-google.xml and you'll see Google will center in on
>> Australia.  If you then click on the OSM layer, it will also show
>> zoomed in on Australia.  The problem occurs when you do the following :
>> put the layer <layername>LYROSM</layername> as the first to draw (so
>> that the OSM layer is the default baselayer showing on load)
>> Switching the layer position in the layertree has no effect.  It's
>> really when the OSM layer is drawn first that the problem occurs.  I
>> wonder if the problem is with the OSM layer constructor we use in GP.
>> Funnily enough, if you try drawing a Yahoo or Google layer first, the
>> initial zoom will show Australia centered.  If you put a Bing layer
>> as the 1st layer to draw, the image will be zoomed in but Australia
>> will show on the right-hand side.  Putting the OSM layer first shows
>> no zoom at all.  Weird ...
>> Cheers,
>> Yves
>>> Alexandre
>> Geoprisma-dev mailing list
>> Geoprisma-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
More information about the Geoprisma-dev mailing list
