[Geoprisma-dev] Cleanup the samples
Alexandre Dube adube at mapgears.com
Fri Dec 10 11:09:10 EST 2010
On 10-12-10 09:51 AM, Alexandre Dube wrote:
> Finally, it is important to notice that in the end, we'll always need
> 2 templates until the Map widget disappear.  Since the MapPanel and
> Layer widget don't do 100% of the features the Map widget does (like
> merging layers), it should be kept.  Since the Map widget also needs
> MapFish-client javascript but not the two others, we need 2 templates
> (unless I find an easy way to detect which widget is present and load
> the according libs).  I'll have to see...
Yep, I was able to have only one template managing the 2 ways with a
couple of 'if'.  So, we'll be able to have only one template, woohoo !
Regards,
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
