[Geoprisma-dev] Cleanup the samples
Alexandre Dube adube at mapgears.com
Tue Dec 14 11:53:28 EST 2010
   Here's an update on the task at hand : "Cleanup the samples".
   They were all cleaned, except the following ones :
## should not be touched
   * acl2
   * borealis-authentification
## others
   * sample1
   * complex_workspace
   * workspace
   I think the three last one show very interesting features, such as :
     * use of the XMLWorkspaceConfig driver
     * use of authentication
     * use of ACL
   Here's what I propose : remove these 3 examples and replace them by
simpler samples demonstrating the same features mentioned above.  I
don't think they should include much widgets, just barely what's
required (for simplicity).
   What do you think ?  Any objections ?
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
