[Geoprisma-dev] Cleanup the samples
Yves Moisan yves.moisan at boreal-is.com
Tue Dec 14 12:06:09 EST 2010
Le 2010-12-14 11:53, Alexandre Dube a écrit :
> Hi,
>   Here's an update on the task at hand : "Cleanup the samples".
>   They were all cleaned, except the following ones :
> ## should not be touched
>   * acl2
>   * borealis-authentification
> ## others
>   * sample1
>   * complex_workspace
>   * workspace
>   I think the three last one show very interesting features, such as :
>     * use of the XMLWorkspaceConfig driver
>     * use of authentication
>     * use of ACL
>   Here's what I propose : remove these 3 examples and replace them by
> simpler samples demonstrating the same features mentioned above.  I
> don't think they should include much widgets, just barely what's
> required (for simplicity).
>   What do you think ?  Any objections ?
Hi Alexandre,
I think it's a worthwhile objective to try and minimize the amount of
widgets (whence, JS to read ...) for a given example.  At any rate, we
can always chime in and modify the examples later on.
Thanx for doing this very much needed first cleaning pass on the
examples directory.
Yves
More information about the Geoprisma-dev mailing list
