[Geoprisma-dev] Cleanup the samples
Alexandre Dube adube at mapgears.com
Thu Dec 16 15:47:30 EST 2010
   Here's the only things remaining to do :
   * sample1/josso -> I'd like to move the "josso" portion to the
"borealis_authentication" sample
   * "borealis_authentication" sample : I'd like every combinaisons to
work if possible.  Currently, only the things set locally work.
   * move the acl.xml file from ./config to the sample dir
   * remove all old .xml file from ./config dir
   * remove all old templates
   * solve the "Windows doesn't include headers/footers" problem
   About point #2, are there existing authentication sources still valid
somewhere I could log on to ?  Else, is it worth keeping to at least
have the code somewhere even though it's not 100% working ?
Regards,
Alexandre
On 10-12-14 02:25 PM, Alexandre Dube wrote:
> On 10-12-14 02:09 PM, Yves Moisan wrote:
>>> Do you mean we should postpone the remaining things for later ?
>> I mean do what you propose for the 3 samples : remove them with
>> simpler ones.
> Okay, thanks.
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
