[Geoprisma-dev] Initialview modification
Yves Moisan yves.moisan at boreal-is.com
Mon Feb 15 12:16:08 EST 2010
Hi All,
I just realized my new <highlight> feature in InitialView has problems
when no layer of type featureserver is created in the map, as is the
case in the initialview sample on geoprisma.org.
I just added some code to take care of that (patch attached).  If there
is no featureserver layer, I just add a cross mark (like the
mapfishrecenter behaviour).  If you run the initialview sample on
localhost with that version of InitialView.xslt, you'll see.
However, I don't know what the behaviour should be to tick the cross
off.  Simply panning around or zooming out ?
Comments appreciated,
Yves
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/geoprisma-dev/attachments/20100215/c34608d3/InitialView-cross.bin
More information about the Geoprisma-dev mailing list
