[Geoprisma-dev] Initialview modification
Julien-Samuel Lacroix jlacroix at mapgears.com
Tue Feb 16 11:49:20 EST 2010
Thank you Yves.
Julien
Yves Moisan wrote:
>> Hi All,
>> I just realized my new <highlight> feature in InitialView has problems
>> when no layer of type featureserver is created in the map, as is the
>> case in the initialview sample on geoprisma.org.
>> I just added some code to take care of that (patch attached).  If there
>> is no featureserver layer, I just add a cross mark (like the
>> mapfishrecenter behaviour).  If you run the initialview sample on
>> localhost with that version of InitialView.xslt, you'll see.
>> However, I don't know what the behaviour should be to tick the cross
>> off.  Simply panning around or zooming out ?
>> Comments appreciated,
> I have just defined an event on mouse click to get rid of the cross for
> now.  That is, any (mouse) event but click (e.g. panning, zooming
> in/out) will leave the red cross showing the center on.  The behaviour
> is similar to unselecting a feature by clicking.  We can always make a
> more intelligent event later on.
> r794
> Yves
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Mapgears
http://www.mapgears.com/
More information about the Geoprisma-dev mailing list
