[Geoprisma-dev] PHP OO to generate a mapfile
Alexandre Dube adube at mapgears.com
Tue Jan 5 08:48:30 EST 2010
Hi Steve,
  I guess this thread should be on the MapServer-dev ML.
Regards,
Alexandre
Stephen Woodbridge wrote:
> Happy New Year Everyone,
> Over the holidays, I took a stab at generating OO PHP Classes that can
> take a PHP hash array and turn it into a mapfile. It works quite well
> but probably needs to additional refactoring. You can see the hash,
> the mapfile and the map image here.
> http://imaptools.com:8080/work/testMapfile2.php
> I want to add a mapfile parser to read a mapfile and create the hash
> and/or the object tree directly.
> My thoughts behind this effort are that it might be useful for
> building a tool that could be used as part of shapefile upload tool
> that would also need to generate or modify a mapfile. While I am not
> using mapscript and prefer not to to keep installation and
> configuration simple, this could also be extended to pass the mapfile
> directly to mapscript so you could provide realtime sample images of
> styling changes. The current demo is using cgi mapserver.
> Thoughts on this?
> I think some of you have thought about a shapefile upload tool.
> -Steve W
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
