[Geoprisma-dev] Move demo to new system, and having issues
Stephen Woodbridge woodbri at swoodbridge.com
Fri Jan 8 14:24:45 EST 2010
Hi all,
I move my Geoprisma demo to a new system and things are not working.
I'm wondering is this was because something changed in trunk? Because
the only thing I can see that is different is the new server is on a new
Revision: 765 and the working one is on Revision: 761. Altought I may
have missed some other config change when moving it.
http://gis.imaptools.com/project/myproj2/
login: test2/test to add a street
Two symptoms:
1) when I add a street, the attribute dialog is not populated with any
fields
2) if I commit the feature anyway I get the following request, response.
Params:
osmservice=S_WFS_IMT_FS
osmtoken=TODO%20Delete%20this
osmresource[]=R_STREETS
Post:
{"type":"FeatureCollection","features":[{"type":"Feature","id":"OpenLayers.Feature.Vector_564","properties":{},"geometry":{"type":"LineString","coordinates":[[-10737947.3757,3775653.8152183],[-10738002.314814,3775759.5132964]]}}]}
Response:
An error occurred: Couldn't create WKT from geometry of type LineString
({u'type': u'LineString', u'coordinates': [[-10737947.375700001,
3775653.8152183001], [-10738002.314813999, 3775759.5132964002]]}). Only
Point, Line, Polygon are supported.
   File "/usr/lib/cgi-bin/featureserver-1.12/FeatureServer/Server.py",
line 298, in cgiHandler
     format, content = service.dispatchRequest( params, path_info, host,
post_data, request_method, accepts )
line 145, in dispatchRequest
     result = method(action)
   File
"/usr/lib/cgi-bin/featureserver-1.12/FeatureServer/DataSource/PostGIS.py",
line 138, in create
     values = ",
".join(self.value_formats(feature)+["SetSRID('%s'::geometry, %s) " %
(self.to_wkt(feature.geometry), self.srid)])
   File
line 98, in to_wkt
     raise Exception("Couldn't create WKT from geometry of type %s (%s).
Only Point, Line, Polygon are supported." % (geom['type'], geom))
More information about the Geoprisma-dev mailing list
