[Geoprisma-dev] Move demo to new system, and having issues
Alexandre Dube adube at mapgears.com
Fri Jan 8 14:59:40 EST 2010
Hi Steve,
  Could you please add the links to your config.xml and template.xslt
files ?  I'd be glad to help.
Regards,
Alexandre
Stephen Woodbridge wrote:
> Hi all,
> I move my Geoprisma demo to a new system and things are not working.
> I'm wondering is this was because something changed in trunk? Because
> the only thing I can see that is different is the new server is on a new
> Revision: 765 and the working one is on Revision: 761. Altought I may
> have missed some other config change when moving it.
> http://gis.imaptools.com/project/myproj2/
> login: test2/test to add a street
> Two symptoms:
> 1) when I add a street, the attribute dialog is not populated with any
> fields
> 2) if I commit the feature anyway I get the following request, response.
> Params:
> osmservice=S_WFS_IMT_FS
> osmtoken=TODO%20Delete%20this
> osmresource[]=R_STREETS
> Post:
> {"type":"FeatureCollection","features":[{"type":"Feature","id":"OpenLayers.Feature.Vector_564","properties":{},"geometry":{"type":"LineString","coordinates":[[-10737947.3757,3775653.8152183],[-10738002.314814,3775759.5132964]]}}]}
> Response:
> An error occurred: Couldn't create WKT from geometry of type
> LineString ({u'type': u'LineString', u'coordinates':
> [[-10737947.375700001, 3775653.8152183001], [-10738002.314813999,
> 3775759.5132964002]]}). Only Point, Line, Polygon are supported.
>   File "/usr/lib/cgi-bin/featureserver-1.12/FeatureServer/Server.py",
> line 298, in cgiHandler
>     format, content = service.dispatchRequest( params, path_info,
> host, post_data, request_method, accepts )
> line 145, in dispatchRequest
>     result = method(action)
>   File
> "/usr/lib/cgi-bin/featureserver-1.12/FeatureServer/DataSource/PostGIS.py",
> line 138, in create
>     values = ",
> ".join(self.value_formats(feature)+["SetSRID('%s'::geometry, %s) " %
> (self.to_wkt(feature.geometry), self.srid)])
>   File
> line 98, in to_wkt
>     raise Exception("Couldn't create WKT from geometry of type %s
> (%s). Only Point, Line, Polygon are supported." % (geom['type'], geom))
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
