[Geoprisma-dev] Maxfeatures
Julien-Samuel Lacroix jlacroix at mapgears.com
Tue Jul 6 09:21:00 EDT 2010
the maxfeatures feature of featureserver is used at several places. It's
even a map widget option. So it should work. Go idea to use it in the
initialview widget though.
Best regards,
Julien
On 10-07-05 04:54 PM, Yves Moisan wrote:
> Hi All,
> Anyone tried passing in a maxfeatures= to a featureserver datastore ? I
> tried adding ?maxfeatures=some_int to the service url and that does not
> work. I understand why I think : the name of the layer is appended to
> the service url as a url complement and then parameters can be shoved
> in, so putting a url parameter in the service name is no good. For the
> initialview widget, we were thinking of limiting the number of features
> to 1 to make things snappier.
> TIUA,
> Yves
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Mapgears
http://www.mapgears.com/
More information about the Geoprisma-dev mailing list
