[Geoprisma-dev] Maxfeatures
Yves Moisan yves.moisan at boreal-is.com
Tue Jul 20 13:56:02 EDT 2010
Le 2010-07-06 09:21, Julien-Samuel Lacroix a écrit :
> Hi,
> the maxfeatures feature of featureserver is used at several places.
> It's even a map widget option.
Somewhat of an old thread caught up in my "Draft" box :
In the case where we have a layer it works to put it as an option in the
map object.  The problem is I want to limit the number of records for
things like the Shortcut or InitialView which are not related to the map
or layer objects.
Cheers,
Yves
> So it should work. Go idea to use it in the initialview widget though.
> Best regards,
> Julien
More information about the Geoprisma-dev mailing list
