[Geoprisma-dev] Maxfeatures
Julien-Samuel Lacroix jlacroix at mapgears.com
Tue Jul 20 14:12:46 EDT 2010
On 10-07-20 01:56 PM, Yves Moisan wrote:
> Somewhat of an old thread caught up in my "Draft" box :
> In the case where we have a layer it works to put it as an option in the
> map object. The problem is I want to limit the number of records for
> things like the Shortcut or InitialView which are not related to the map
> or layer objects.
> Cheers,
> Yves
Oh right! Than go ahead to make the initialview set the maxfeature.
Perhaps as an option. It will definetly won't work if you put it in the
datastore declaration.
Julien
Mapgears
http://www.mapgears.com/
More information about the Geoprisma-dev mailing list
