[Geoprisma-dev] Time frame/estimate to implement these features
Yves Moisan yves.moisan at boreal-is.com
Wed Mar 10 08:34:33 EST 2010
Julien-Samuel Lacroix a écrit :
> Hi,
> I'm not sure yet what are my priority for the next features. I guess
> it will become more clear as time go. For other comments, see inline:
>> 1) Feature and WMS filtering (http://trac.osgeo.org/geoprisma/ticket/38)
> We've already discussed the syntax of the config file for that, but
> behind the scene it's possible to do filtering on WMS with a SLD and
> te Filter Encoding OGC Spec (supported by MapServer and GeoServer) and
> to use FeatureServer query capabilities like you proposed.
Thanx Julien,
Can you outline what that means for GeoPrisma so I can estimate the
time?  At one point we were thinking about a "style registry" of some
sort (e.g. per user or per user roles) so maybe that would be an
opportunity to implement that kind of thing ?
> For extent based Filtering it's trickier because we have to decide
> what to do with request outside the bounds. My take is to drop all
> request for something outside the filter or return an empty image.
That would be my take too.  But maybe using a different
(restricted)extent in another workspace could do the job.
Cheers,
Yves
More information about the Geoprisma-dev mailing list
