[Geoprisma-dev] min/max scale issue
Yves Moisan yves.moisan at boreal-is.com
Wed Mar 24 16:50:56 EDT 2010
> I think it is more complex an issue because you need to "virtually
> off" but you need to remember state so when you zoom back out you can
> turn it  on again. IE: zooming should not permanently tick/untick
> selections.
Hi Steve,
You've got a point there.
> If a control is ticked on and then disabled from zooming then it
> should also be disabled for viewing, but I'm not sure you would want
> it ticked off.
Some event ;-).  But you're right there's a stateful dimension here that
we'd need to cater for.
Thanx,
Yves
More information about the Geoprisma-dev mailing list
