[Geoprisma-dev] TileCache direct cache access now supported
Alexandre Dube adube at mapgears.com
Fri Sep 3 13:51:00 EDT 2010
On 10-09-03 01:31 PM, Yves Moisan wrote:
> Hi Alexandre,
> Thanx for this update.  I want to underscore that this will NOT go
> through a WMS so the images MUST be in the cache or else you'll get
> pink tiles.
Indeed.
> Do you have an idea of what the performance gain is ?
How faster I don't know (didn't test it), but theoretically it's faster
to simply ask for an image directly than asking a tile server script
that is going to check if the tile exists first.  I noticed a slight
difference on the sample when I put the option on.
Regards,
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
