[Geoprisma-dev] TileCache direct cache access now supported
Yves Moisan yves.moisan at boreal-is.com
Fri Sep 3 13:31:35 EDT 2010
  Le 2010-09-03 11:46, Alexandre Dube a écrit :
> Hi,
>   Some of you might be interested in this new fix [1] in GeoPrisma.
> The use of the new service option "staticCache" (when set to true) in
> a <tilecache> service make GeoPrisma-Client create
> OpenLayers.Layer.TileCache layers instead of WMS, making the requests
> access the web cache directly.
>   When using it :
>   * You need to set the according <source> parameter of the service to
> the web cache.
>   * Beware of the "format" layer option.  It must be the same as the
> image type of your cache.
>   * Don't forget to seed your cache first
Hi Alexandre,
Thanx for this update.  I want to underscore that this will NOT go
through a WMS so the images MUST be in the cache or else you'll get pink
tiles.
Do you have an idea of what the performance gain is ?
Thanx again,
Yves
>   For more, look at the comments of the ticket.  There's a sample link
> in it.
> Regards,
> [1] http://trac.osgeo.org/geoprisma/ticket/144#comment:1
More information about the Geoprisma-dev mailing list
