[Geoprisma-dev] TileCache direct cache access now supported
Alexandre Dube adube at mapgears.com
Fri Sep 3 11:46:39 EDT 2010
   Some of you might be interested in this new fix [1] in GeoPrisma.
The use of the new service option "staticCache" (when set to true) in a
<tilecache> service make GeoPrisma-Client create
OpenLayers.Layer.TileCache layers instead of WMS, making the requests
access the web cache directly.
   When using it :
   * You need to set the according <source> parameter of the service to
the web cache.
   * Beware of the "format" layer option.  It must be the same as the
image type of your cache.
   * Don't forget to seed your cache first
   For more, look at the comments of the ticket.  There's a sample link
in it.
Regards,
[1] http://trac.osgeo.org/geoprisma/ticket/144#comment:1
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
