[Geoprisma-dev] Options for ressource in Workspace
Djoan Bonfils djoan.bonfils at boreal-is.com
Thu Sep 9 15:20:54 EDT 2010
  Hi Alexandre,
> /Hi Djoan,
>   First of all, when you wish to start a new topic, please create a
> new message instead of using an old message, clicking "reply-all" and
> changing the subject. When you do so, the message gets indented in the
> old thread and that can be a little confusing. /
Thx for the precision concerning the list.
>   If you only wish to have a specific workspace that has no
> mapfishlayertree widget at all in it, you can define an alternative
> <layout> that point to a template.xslt file that draws no tree widget
> in it.  That would work.  See in the ./samples/workspace/config.xml
> file for an example of how to define an alternative <layout> for a
> workspace. /
Yes this is working, we already did that.
>   If you wish to have a specific layer not visible (unchecked) by
> default in the mapfishlayertree in a workspace, then you would need to
> develop this feature since it's not supported by the
> XMLWorkspaceConfig driver.  There's a ticket open mentionning this
> kind of feature but it's related to the PGSQLMapContextConfig driver
> [1] only. /
Yes or the contrary (have a specific layer visible (checked) by
default), we'll see with the team what we can do. I think this feature
will be required for us.
Thank you!!!
Djoan Bonfils
Gis&  Business Analyst
Boréal Informations Stratégiques
         www.boreal-is.com
101, Du Moulin, bureau 202-A
Magog (Québec)
J1X 4A1 CANADA
Tel :  +1 514 313 5951 #1128
URL: http://lists.osgeo.org/pipermail/geoprisma-dev/attachments/20100909/f914e170/attachment.html
More information about the Geoprisma-dev mailing list
