[Geoprisma-dev] Options for ressource in Workspace
Alexandre Dube
adube at mapgears.com
Thu Sep 9 15:13:44 EDT 2010
Hi Djoan,
First of all, when you wish to start a new topic, please create a new
message instead of using an old message, clicking "reply-all" and
changing the subject. When you do so, the message gets indented in the
old thread and that can be a little confusing.
If you only wish to have a specific workspace that has no
mapfishlayertree widget at all in it, you can define an alternative
<layout> that point to a template.xslt file that draws no tree widget in
it. That would work. See in the ./samples/workspace/config.xml file
for an example of how to define an alternative <layout> for a workspace.
If you wish to have a specific layer not visible (unchecked) by
default in the mapfishlayertree in a workspace, then you would need to
develop this feature since it's not supported by the XMLWorkspaceConfig
driver. There's a ticket open mentionning this kind of feature but it's
related to the PGSQLMapContextConfig driver [1] only.
Best of luck,
Alexandre
[1] http://trac.osgeo.org/geoprisma/ticket/121
On 10-09-09 02:54 PM, Djoan Bonfils wrote:
> Hello,
> I was wondering if it was possible to enable options for the
> resource/layer specifically for a workspace.
> For example, we might want to set a layer as checked and active in a
> specific workspace when it's not in the global. This case occurs for
> us in V2 when we display maps in V2 forms and we don't want to enable
> the mapfishlayertree. Apart from duplicating the resource I don't see
> any workaround...
> Thanks for your help.
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
