[Geoprisma-dev] RFC - switch to Ext 3.2.1
Alexandre Dube adube at mapgears.com
Thu Sep 30 09:40:44 EDT 2010
Ticket created, which should be fixed in the following hours/days :
http://trac.osgeo.org/geoprisma/ticket/155
Kind regards,
Alexandre
On 10-09-29 01:41 PM, Yves Moisan wrote:
>  Le 2010-09-29 10:24, Alexandre Dube a écrit :
>> Hi,
>>   The trunk version of GeoExt now uses Ext 3.2.x features, such as
>> Ext.slider.tip.  If you update your externals, you'll see that you'll
>> see new javascript errors occurring.  In the GeoExt-dev list, Andreas
>> Hocevar mentioned that GeoExt 1.0 (currently rc1) requires "Ext JS
>> (version 3.2 or higher recommended)".
>>   I propose to remove the current ext-3.0.0 lib we use and replace it
>> for ext-3.2.1.  Changing the ./samples/config.php "g_ex_ver_extjs"
>> config to ext-3.2.1 should do the trick of updating all samples to
>> use the new version (thanks Pascal for that brilliant feature).
>>   If we all agree, I would create the ticket and do what's required
>> to apply the change.  If by any bad luck we have some breaking
>> features occurring because of that change, they would need to be
>> fixed in order to work with 3.2.1 (each issue would have its own
>> unique ticket with a mention to the "switch to 3.2.1" ticket).
>>   I'll start with my +1.
> +1 here too.  In fact we've been distributing GP with 3.1.2 for some
> time now (we have an ExtJS commercial license) because we found some
> issues with 3.0.0.
> Thanx,
> Yves
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
