[Geoprisma-dev] RFC - switch to Ext 3.2.1
Yves Moisan yves.moisan at boreal-is.com
Wed Sep 29 13:41:53 EDT 2010
  Le 2010-09-29 10:24, Alexandre Dube a écrit :
> Hi,
>   The trunk version of GeoExt now uses Ext 3.2.x features, such as
> Ext.slider.tip.  If you update your externals, you'll see that you'll
> see new javascript errors occurring.  In the GeoExt-dev list, Andreas
> Hocevar mentioned that GeoExt 1.0 (currently rc1) requires "Ext JS
> (version 3.2 or higher recommended)".
>   I propose to remove the current ext-3.0.0 lib we use and replace it
> for ext-3.2.1.  Changing the ./samples/config.php "g_ex_ver_extjs"
> config to ext-3.2.1 should do the trick of updating all samples to use
> the new version (thanks Pascal for that brilliant feature).
>   If we all agree, I would create the ticket and do what's required to
> apply the change.  If by any bad luck we have some breaking features
> occurring because of that change, they would need to be fixed in order
> to work with 3.2.1 (each issue would have its own unique ticket with a
> mention to the "switch to 3.2.1" ticket).
>   I'll start with my +1.
+1 here too.  In fact we've been distributing GP with 3.1.2 for some
time now (we have an ExtJS commercial license) because we found some
issues with 3.0.0.
Thanx,
Yves
More information about the Geoprisma-dev mailing list
