[Geoprisma-dev] RFC - switch to Ext 3.2.1
Julien-Samuel Lacroix
jlacroix at mapgears.com
Wed Sep 29 10:55:11 EDT 2010
Hi
+1
Julien
On 10-09-29 10:24 AM, Alexandre Dube wrote:
> Hi,
> The trunk version of GeoExt now uses Ext 3.2.x features, such as
> Ext.slider.tip. If you update your externals, you'll see that you'll see
> new javascript errors occurring. In the GeoExt-dev list, Andreas Hocevar
> mentioned that GeoExt 1.0 (currently rc1) requires "Ext JS (version 3.2
> or higher recommended)".
> I propose to remove the current ext-3.0.0 lib we use and replace it for
> ext-3.2.1. Changing the ./samples/config.php "g_ex_ver_extjs" config to
> ext-3.2.1 should do the trick of updating all samples to use the new
> version (thanks Pascal for that brilliant feature).
> If we all agree, I would create the ticket and do what's required to
> apply the change. If by any bad luck we have some breaking features
> occurring because of that change, they would need to be fixed in order
> to work with 3.2.1 (each issue would have its own unique ticket with a
> mention to the "switch to 3.2.1" ticket).
> I'll start with my +1.
Mapgears
http://www.mapgears.com/
More information about the Geoprisma-dev
