[Geoprisma-dev] Editing widgets - in production ?
Yves Moisan yves.moisan at boreal-is.com
Tue Jan 18 11:20:08 EST 2011
> Hi,
>   Is anyone currently using the editing widgets in production ?  We
> would like to modify them in the following days.  If no one ever used
> them, we would make the changes without thinking "backward
> compatibility".
> Best regards,
Hi Alexandre,
You can consider you have a blank slate to start with.  One issue we
have found with the edit widget is that we needed to use fake sequences
to make it work with PG views.  This is probably not related with the UI
though.  Just in case.
Cheers,
Yves
More information about the Geoprisma-dev mailing list
